Old 01-22-2012, 12:19 PM
Originally Posted by abl1111 View Post
I remember that seat you did. It's still is as mind-blowing as when I first saw it. Awhile ago, I mentioned to you I saw your boat in my Long Island waters - to a guy you sold it to. I noticed the beautiful hull, but when I saw the seat - I knew it was your boat !
Questions:
I'm not even going to bother asking about the foam shaping etc. Completely out of my comprehension... When you make a 'normal' radius with cabosil and after it kicks - are you worried about scratching up the mold when you try to smooth out the cabosil radius ?
I understand using the core cell for stiffness, but if I want to mount something to the seat box I want to build, should I use something STRONG, like plywood that can be mounted to ?
That was probably the best boat I will ever own. But it was a little too big for getting into some of the tight places that I like to fish in the delta. The 20 is much better suited.
The core cell has a very high compressive strength. If you are worried about strength then throw a couple extra layers of 1708 down in key areas. What you are going to mount to a seat box that will create shear and compressive forces that can crack the laminate?
Cabosil alone is too hard to sand so it does not make a good material for fillets. Mixed with microballoons it is much easier to sand. If you are careful during application then you can keep your sanding down to a minimum and you will not scratch up the mold enough to effect it.
Sean thanks for the the link I'll check it out!
