Old 01-25-2012, 07:58 AM
bly bly is offline
Default Not sure what percent of resin ratio you are trying for? Be careful.
Well, the polyester peel ply worked. The nylon, not so much.
The polyester peel ply allowed me to get what seems to be a pretty good resin ratio with just a squeegee. Not dry, but not a lot of excess. I will have to try more than a sample coupon next to verify.
The urethane foam is pretty soft, but the epoxy adhesion was stronger than the foam itself. Not that I expected something different from what Bly reported.
I have found it is more worser to be too dry then too wet. Yes it is heavier. But in my quest for lightness I have found that I have sometimes resin starved the laminate after trying to get the excess resin out. Peel plys are great for leaving a nice surface also. I always have peel ply around the shop. I sometimes for get to get all my toys out of the toy box til its too late tho. On that urethane home depot foam. I have a sheet on the floor to roll my glass out and cut, why? Its nice and soft on the knees.
