the pictures - these do not show the depth of those pits
pitting like this is trouble ! attempting to repair this is asking for trouble...
tanks - aluminum tanks - should be chemically etch primed and coated in a waterproof coating,to the proper thickness - i use interprotect 2000e - this is a waterproof barrier,it seperates the aluminum tank surface from water - this is a good,reliable coating method - done in the correct manner,the tank will last indefinatley...
if your fuel system is in the 10yr range,i highly reccomend you pull that tank and inspect it !
