Old 03-02-2012, 09:37 AM
All I know is on the 21 they used aluminum rivets and then taped the cap to the sides. The size is like a 10/24 bolt. You should only have enough of the rivet sticking thru the combined material and washer to get a mushroom when you pull it. Anything more than that is actually a determent.
I think the reason they use rivets rather than bolts is a two fold. First faster and second it has a consistent pressure on each one applied.
Hope this helps. Check out http://www.mcmaster.com for a huge selection of rivets.
