Old 03-04-2012, 10:31 PM
martin martin is offline
Default pictures
Pulled the outdrive off and inspected the gimble bearing.. Looks brand new.. the shaft and splines on the Outdrive are excellent shape as are the ujoints.. it comes with a 21 pitch cupped prop from power tech item # m400bra 21pitch ... this unit did not get much use when installed in have all paper work that shows the maintenance since 05 last year it was registered.. Pulled the motor out the exhaust and riser where spotless . there is not water in the engine. The heat exchanger was spotless. No corrosion whatsoever. There was fresh antifreeze through out engine. oil was clean ,distributor clean,needs new alternator and rebuild raw water pump...
