Old 04-01-2012, 09:27 AM
ScottM ScottM is offline
Dieter Sprockets
Originally Posted by BigLew View Post
I've got a question, though I suspect I know what the answer will be. What do you use to tow that rig? If anyone would like to chime in on towing a Scepter with a BIG outboard or I/O, I'd like the hear that as well. I really don't need a pickup, but might do one if it makes sense.
Lew,
If you want to do it comfortably (and safely), either a 1/2 ton P/U or full-size SUV will do the trick. But if you only need a tow vehicle for short runs and/or the spring drop-in/fall haul-out, you can make due with a mid-size SUV. My father always kept his Sceptre at a slip, so we only needed to haul his boat a couple times a year over 6-7 miles of back roads. Over the 14 years he had it, we towed it with a '00 S10 Blazer 4.3L V6 (I don't recommend this), a '00 F150 extended cab 5.4L V8, a '98 F150 reg cab short bed 4.6L V8 and a '03 Ram reg cab short bed 4.7L V8. Of all of those vehicles, my F150 5.4 did the best job out of the lot mainly due to the larger motor but also because of the longer wheelbase.
