wrapping it up now......
Installing GPS/sonar, had to make another hole in the transom for the cable, I had hopes the tube I made for the trim tab cable would be big enough to also fit the tranducer cable, but the plug on the ducer cable was too wide (and you know you can not cut those things).
hole drilled
hole coated liberally with epoxy
PVC liner sanded to get good bond
I cut a mixing stick in half, length wise, to make a "butter knife and use it to coat the inside of the hole. Then I put some on the tube before threading it through, I turn it as I slowly push it through. I put some electrical tape on the end of the pipe so the putty does not get in the tube, then when it all cures I cut the ends back with the multi tool. BTW, the blue tape there is to catch the epoxy so it does not run down the boat.
filled with life seal
I went with a Humminbird 998 side image. Found a pretty good price on it, for about as much as most other places were selling the 898. Not cheap, but this whole boat is built around finding fish (specifically bottom fish), so to skimp on the one tool that will make it MUCH easier to find good bottom seemed silly. Hopefully I will have a good handle on how to read it by the time the keys trip in June. You can see from the pictures I made a mount that would allow me to remove the unit but have it in the dash, dash is only 4" deep so it just barely fits and I can still close the glass. Looks a little funky, but its the best compromise for what I wanted (removable but still in the dash)
Re-wiring the boat: Until this point I have installed everything willynilly to make sure it worked and to see how I liked the layout. Have I mentioned I dislike this part of boat build :? Took everything out and Im now putting it all back, somewhat organized.
Got a new prop: 14.25 x 19 stainless, the one I had on first was for a smaller engine 13.75 x 17. So its a big step up, so we will see what happens.
