Old 04-20-2012, 09:17 PM
FishMagnet FishMagnet is offline
Thanks Chuck. I am pleased with how its coming together.
The forward deck hold is plumbed to drain thru pvc pipe back to a thru hull in the transom.
I am not using the Armstrong ladder-I had a Schmidt and Sons ladder that installs under the bracket and can be deployed from the water. We will bolt that back on after painting it.
I believe that the anchor and foward bow flush mounts will drain into the bilge but I need to confirm that. If not I will have them make a drain hole thru the anchor locker to the outer hull.
