Originally Posted by hugo
the cav plate is even with the bottom, and the factory beatup looking aluminum prop runs great, i was looking to get even better holeshot than i have already. i dont care about losing any speed on top as i was told i would because the boat flies already faster than i would ever run it. and i wanted to get a SS prop. i thought it would be a huge improvment but it just seemed to start out ok then vent ( reving real high and no go) and i had to ease out of the gas then get back on it to get it on the pad. once it was up it seemed ok but not as good as before. could the one small hole vent cause this?
No . . . I don't think one hole would cause this. For $2 you can be 100% sure. Are you sure you have a large hub 4 3/4" prop? You might measure it to be sure. If you are running a small hub 4 1/4" Trophy Plus prop on a 4 3/4" lower unit that would explain your issue.
Try putting the aluminum prop and the trophy side by side and measure the hub. I'd be willing to bet you will see one is 4.75" and the trophy plus be 4.25".
