Gentlemen,
thanks for the replys this is not the first time i have glassed but the first time I have used an ester resin i gennerally used epoxy and was able to do my glassing in a controlled environment. I was trying to rush and get the job done rather than laying out the job first. I became a victim of get the boat done and in the water rather than doing a thorough job. I have since cleaned and ground down my penske core and will again attempt to relaminate. my schedule will be to 1st skim coat core with some thickened resin to fill in the low spots from grinding then I will place layer of 1.5oz matt on both sides let that set up then add a layer of 1708 let that tack up then use thickened resin to set the core and use screws every 8" to clamp then let it sit for 2 days.
