Old 05-04-2012, 10:11 PM
Originally Posted by YeA 20sF View Post
Thanks Blue, so basically the location of the one in the first pic would be the best spot for the new one. When I remove the old ones do I just fill the old holes in with 5200 or should I do something else ?
The location of the original transducer may be a little close to the engine. As Big Lew mentioned, the Garmin installation instructions should give you some guidance on minimum distance. If Garmin says it's ok, you should be good.
On the holes for the old transducer and speed sender, 5200 will work, but if you can drill them out a little and pump some thickened epoxy resin in them that would be a more permanent solution.
Dave
Blue Heron Boat Works
