Originally Posted by jesusv
as i was removing the glass on the transom to remove the coring i cut back the stringers, as i mad my first cut midway up the stringer water begins rolling out. i made another inspection cut about 1.5 feet from the transom and same thing. what now? its a 23 inboard and im in south florida dont know if i should be putting this much time into an inboard, which is a great boat but realistically an outboard would be much better for so. fl.. thinking my time would be better spent on an outboard model. any suggestions, advice?
If the floor is in good shape . . . I'd try to dry out the foam without ripping the boat apart. You can use a hole saw and drill a few 2" holes in the stringer (2" up from bottom of the stringer) to get a better idea of the situation. It's far easier to patch bunch of 2" holes than replace the entire stringer and floor
. What I've seen in a few other boats is that only the bottom 1" of foam gets wet and the rest of the foam inside the stringer is dry . . . If that's the case just you can fix it easily without ripping the entire boat to pieces.
