those will work fine. i like blue sea fuse boxes because you can use automotive atc fuses. i have 2 in both of my boats and had no problems with them. if the terminals are corroded you should cut back until you get to good wire and crimp on a new terminal with adhesive lined heat shrink. none of the wires look heat shrinked in your pictures. you might want to consider replacing some of the wires with tinned. i like to put dielectric grease on the connectors to help keep salt air off them.
