Originally Posted by mnwnvc
I use a counter sink on each hole to make it taper from wide on top to narrow on the bottom. Place a piece of blue painters tape over the hole on the underside. Mix thickened epoxy and fill hole. Cover with a piece of plastic wrap and smooth with a thin putty knife and allow to cure. Requires only a light sanding and maybe a little fill in places.
i like the plastic wrap idea. i usually use a razor blade to smooth it while it still wet.
