Did the bases for the bilge pimps and thru hull today tomroow I'll glass them in
Install a battery and switch but did not do a permanant job, I just wanted to start the engine.
Put some gas in the tank and hit the switch and it started with no trouble at all.
What a relief that it started and ran good I need to fix the lower unit seal as is is leaking lower unit oil in the propeller area and change out the impeller.
I will more than likely do some minimal electrical done and finish as the summer progresses and see what I need
The trim....... I guess I need some type of relay or something to get it going.
On the bottom of my binicule the is a set of 3 wires that finishes in a plug that should go to something.
What is it that it plugs into and where do I get it
What do I need for this?
Next I need to do the trailer so I can get it in the water
I'm so close to getting in the water I can smell it
