Glassed in the bases for the 2 bilge pumps and the base for the thru hull
Installed both pumps and the thur hull and pump I need to get the electric to them but that will be sometime this week. I also need to get the 2 batteries connected to the battery switch
Installed the fuel gauge in the dash but not to the sender, next is the tach
Played with the trim and got that going but I think I have 1 selenoid that is bad and I need to get the trim fluid right. I bought some today and when I was adding it the fluid that was in there came up to the top did not look right, not that it had water, but it may be just old. I would like to flush it out and in with new fluids.
next I really need to get the trailer going as I will be needing to move the boat to the mechanic to get the lower unit looked at, I am leaking lower unit oil from the seal on the prop shaft and I want him to look it over before I go any where
And boy was it hot today!!
I guess pics will be asked for and they will up tomorrow
