j i would take a die grinder with a 3'' cut off wheel and cut 1 1/2'' down from the top all the way around it and remove the top layer. see if it's solid wood ,if so add a new top layer and re glass. if it's wet keep removing it. the mounts in my boat were lag bolted with ss lags. you may find the need to move the center console a little farther forward to offset the wt you removed from the bow and maintain your waterline and may pick up some space behind the leaning post too
