yep this one
http://capecod.craigslist.org/boa/3068879352.html
The only thing I would check before committing is the width of the engine box because the V6 will be wider (but shorter) than the 3.0L. The 4.3L will be the same dimensions, motor bed mounts, exhaust manifold width etc as a 305/350 chevy. If I remember right, that boat came to you with a V8. If thats the case it would be a bolt in swap, barring a different out drive and rotten motor beds that need to be rebuilt. Also the 4.3 is about 300lb lighter than the 3.0.
