I'm ready to drill my first hole in my new transom. An important one, the drain plug.
So; what methods have you guys used?
Do I just drill out the hole and coat it with epoxy?
Do I drill out a larger hole fill it with an epoxy paste and drill out a smaller hole?
Has anyone drilled the hole, epoxy coated it, and slipped in a piece of PVC and recess it to the back of the base?
Then it appears you would drill the holes for the plug base fill them with epoxy paste and re-tap and seal the base with 5200 or do you epoxy the base also.
Of all the posts I don't recall anyone documenting this step.
Thanks' wildbill
