ahhh the Looper.
Hey Snook...have you done the compression check? If good.....you can use a cheap Napa inline spark tester to look over each cyls fire. Especially since it runs for you. In the movie it almost looks like a lean pop but its hard to tell. A close look at the plugs may give away the funky cyl.
coils are cheap....and the carbs are easy (all 6 arg) if you need to get into em again.
1974 23SF
