with a plywood core double the diameter at a minimum, with a foam core, you might need high density insert, depends what kind of load you put on the fastener.
I have had good success with just drilling pilot holes into the epoxy plug. Pilot hole is a little smaller that a self tapping SS screw and using some 5200 or lifeseal to lock it in.
