Originally Posted by strick
Your boat is going to be solid as a rock with that coring in place. I put Balsa in mine and am very happy with how solid the boat is. Nice work!
Thanks Strick,, By the way, How did you blend the top cap with the transom? Did you flare your cap out a bit for the transom crown.? oh and it looks like you just added two inches to the Stringers. i thought about raising mine but it does not give much freeboard.. i am trying to determine the waterline .. Should i just Put boat in water and load with blocks till i get the correct weight .. Tryng to determine the Scupper height. I see yours is perfect just above the sheer .. Ps I was wondering if anyone has tried to flip a 20 over on her top. I want to keep the deck cap on and work on her from the inside So I don't loose the lines i have now..I still need to core the underside of the top deck. So I thought about flipping her over with cap still attached.. I am afraid that if i core the underside with cap off i will disort the top cap
