Originally Posted by eggsuckindog
google evinrude primer, you'll get an explanation
Snook...I would have to look in my book. The primer manual bypass (red switch) should be in closed position when running normal. I probobly have one if this is your problem.
are you still having problems?
Yes...blue powerpack is a CDI unit and not OMC/Factory orig. So it has been replaced at some point if its blue.
Sandy....no Optical eye on the 225 looper. Its not an Optical Ignition System (OIS).
