  #35
Old 07-10-2012, 11:16 PM
Let us know as soon as you have the data.
Raising the motor one hole got me a little. Maybe a knot of speed, but only if I trim the motor to a point where it starts to ventilate a bit, I think. When I did that, I could jump on the throttle and slip or ventilate to get to 5900 RPM occasionally.
But the extra speed came at the same 5600 RPMs, steady state, withou crazy trim- so that's good. And the cable steering is better (lighter). But I need a hydraulic helm.
I will check throttle adjustment tomorrow. If that is correct then I will bolt on the 15 pitch. If not, then I will adjust it then try a top speed run again.
