  #50
Old 07-15-2012, 11:12 PM
By the way, How did you blend the top cap with the transom? Did you flare your cap out a bit for the transom crown.? oh and it looks like you just added two inches to the Stringers. i thought about raising mine but it does not give much freeboard.. i am trying to determine the waterline .. Should i just Put boat in water and load with blocks till i get the correct weight .. Tryng to determine the Scupper height.
1. On the cap I built a mold. It's in the photos of the rebuild. The part (new crown) is glassed to the top of the transom. Better to raise the stringers in the 20 that way you are assured good drainage.
2. Scupper height is determined by your floor height.
3. Never seen anyone work in the inside of the cap with the whole boat up side down. If you brace the cap properly and take it off the boat you should be fine. Opps looks like you have already covered that one
