you can disconnect the kill switch wire at the motor (see above, black with yellow tracer) if you remove it at the motor and kill switch is the issue the boat will start. You then have to ground the spot where it connects at the motor to shut off the boat. Not sure how that wire is connected on your motor, you may have to cut it. On my etech I had to cut it, I crimped a disconnect there for future needs.
