Old 08-07-2012, 10:50 PM
Originally Posted by sidelock View Post
If WOT RPM is higher than the manufacturer's listed RPM range for the specific motor, could it cause any damage to the motor if you run it higher than its RPM range ?
That's much less likely to cause damage than lugging the motor! (running BELOW the recommended RPM range at WOT by running a prop with too much pitch/diameter!) Check out that E-Tec link in my earlier post for more info. Most modern motors like the E-Tec have speed limiters built in to the EMM that will keep you from over revving them.
