Originally Posted by fdheld34
[COLOR=#1f497d][SIZE=3][FONT=Calibri] Should I cut in from the top, remove all traces of wood, leaving bottom fiberglass core intact and replace with new wood soaked in resin and then fiberglass on top? or somehow go in from the underside?
Soaking or painting wood with polyester resin does very little to water proof it. Epoxy is much better if you are planning on trying to coat/soak your wood coring.
