Old 08-09-2012, 08:46 PM
Originally Posted by sidelock View Post
How do I check the tach for accuracy ? I quess you can tell by now that I'm a newbie ! & eager to learn.
No problem - the best way to learn is by asking questions!
I've seen analog tachs that were off by 500 rpm! If you have a digital tach tied into the engine computer/Engine Management Module (EMM), it should be fine. You can check an analog tach on an E-Tec by hooking up a laptop to the motor with diagnostic software in it and comparing rpm on laptop to the tach reading. Sounds like you have a carb'd 2-stroke motor however, that may not have an EMM, only an electronic ignition. In that case you'll just have to hook up a known good tach to it. There are handheld optical tachs that use a strobe light on a timing mark that are very accurate. If you're looking at buying a prop from a dealer, maybe they would check it for you.
