Old 08-22-2012, 06:56 AM
pelican pelican is offline
Originally Posted by Max_Florida View Post
I recored the soft spots on my deck and then completely sanded down the diamond non-skid and painted it. I used Interlux Interdeck.
My first attempt I put it down just a little too thick and it ended up not curing until long after I started using it... I ended up sanding it back down and repainting it.
The 2nd attempt worked much better and so far I am fairly happy with it.
I think if I were to re-do it I might go with something more along the lines of this: http://ultratuffcoatings.com/ultra-t...skid-coatings/
I use my boat primarily for spearfishing so a lot of gear gets slid around the deck and the result is I already have some scuffs and black marks and whatnot.
Whatever paint/coating you decide to go with will dictate the process and your application method.
that product,"interdeck" ,is a single part cheap crap paint - singe part paints never really cure - it is what it is,cheap low quality crap...
the smart way to refinish the deck is to ,sand it down,tape it out,use a good quality 2 part primer,and roll it out in awlgrip,sprinkle with grip tex and roll it again,then one more time...
this holds up,and looks great,compared to that cheap interdeck...
