Good package if its in good shape. Sceptre-Tsunami, same thing.
How many hours on each? If the seller can't tell you, assume a lot.
Is the bravo 1 the old style or new style. New is better built.
If you are buying an expensive boat, its worth investing in a good moisture meter if you can't access one otherwise.
15 years is getting long in the tooth in Florida and the transom is likely soft, unless you have very good reason to know otherwise. Make sure the boat has stayed north.
