Old 09-05-2012, 06:34 PM
sidelock sidelock is offline
My 3/4 " thru hull is 90 degree also but I will take a good look & see if a 1 1/8" straight fitting will clear the protruding threaded tip of the stern lift eye inside the transom compartment & the legs/bolts of the new GEM lift-up cleats I just installed .
Having said that there is a pretty good strong flow out of the existing set up with the 3/4" 90 degree but I would imagine it will be a lot better with straight 1 1/8" fittings.
