Old 09-14-2012, 06:47 PM
Originally Posted by Ulf View Post
New Seacraft owner, '74 20'cc with a Merc 150 Blackmax.
Finally installed the GPS unit, topping out at 43/44 mph @ 5400 RPM. One person, light load, 1/2 fuel?
Does this sound right to you guys?
Running a stock Merc 14x19 s/s dog ear wheel.
Could I get more MPH with a different style prop?
Also think I can go up at least a bolt hole on the transom. My cavitation plate is below transom at nuetral/ negative trim. How are other boats set up with engine height ?
Just looking to make it as efficient as possible.
Thanks Guys
Welcome, the nurse will see you shortly.
Move up 1 1/2 " above keel. Do a comp test on the Max. Do the annual service.
That should get the rpm and speed up a tad. Those numbers are about right.
A powertech, mirage+, bravo, enertia, or rev 4 are some props that are favored.
Google the#s on yours to see what you have.
Avoid e 10 at all cost. Use good oil and decarb. Check the steering arm for integrity.
Add location to your acct. so locals can share/swap/ trade pieces/parts and help/advice.
Cheers,
GFS
