easiest way to determine,is to disconnect the cable from the linkage on the engine - try and move the linkage - if it's rough,the seals are the poblem,if it's freely moving,then the switch is the problem...
no water will be noted in the lower unit - salt wicks moisture,the o rings will actually pry against the shaft,"tightening" the shaft - it's a very common problem...
