Thread: Rub Rails
Old 10-01-2012, 08:49 PM
Time has come to order rub-rails
After talking to a few suppliers I am now more confused than when I started.
Here is my two part question.
Do I want a rigid or a semi rigid rub rail Pros or Cons. Plus I would like to have a s/s insert.
Second part do I screw or rivet the rub rail in?
Thanks,
You know the drill.
Pilot hole.
Countersink in reverse to start.
Rivets will cause spiders to invade your Twin Vee.
I saw cap gaps of over an inch filled with insert your caulk here. Bad factory tour. Nothing but chop guns. English was broken.
I can taste your pride. Drill and tap? Machine screws?
You may consider a hard rail if you wan`t a rail with an insert.
Cheers,
GFS
