Old 10-19-2012, 01:07 PM
Brooks Reid Brooks Reid is offline
Default Mariner 150 Outboard pics
Here is the 1992 Mariner 150 HP with added Bay Manufacturing 25" extension kit and Hydro Jacker installed. Since the transom was raised to 25" this needed to be added. Jack Plate was intended (by previous owner) to allow 20" to be used with 25" raised transom but not a good idea. Could not tilt and steering did not fit. Had to remove engine, fill and re-glass holes in transom and then remount Jack Plate in correct position once Bay Manufacturing 25" kit was installed. The outboard sat outdoors uncovered for 10 years. Thank goodness I kept it coated with WD40 before I sold it. No rust and it still looks and runs like a new motor. About 100 hours total on it maybe.
Replaced the power packs, water pump, fuel pump, carbs cleaned, coil wires replaced, stator wires reconditioned, and spark plugs.
[IMG][/IMG]
