Old 10-22-2012, 06:55 AM
Lordwrench Lordwrench is offline
The transom has already been replaced, just need to make sure the sititng in the rain for so long didn't saturate around the holes.I can't tell until I clean it up wether the holes were epoxied coated after drilling by the previous owner during the last rig.A very respected local glass shop did the transom,I am hoping they did,but I am not sure if the shop did the rig after the transom replacement or the PO.The two scupper holes are the largest,about 3/4 or smaller,the tube on the left side is cracked where they rolled the edge during installation,so they are coming out.The deck still has the original thru floor/vacuum scupper as well,so I am considering options for the transom drains.I think I may just set up some drainage into the bilge from the deck to supplement the thru floor scuppers. I will use custom mix epoxy if there's a viable benefit over six10 but of course simplicity and ease of use is nice as I have limited to zero shop space.
