Thread: Braket build
Old 10-24-2012, 05:32 AM
how many layers are over your braces..did you put .as many layers as your sides .. Or less.. And also did the motor mount go in after the 3/8 thickness was attained on the outside.. How many layers on top of the foam/plywood. Motor mount
I will be laminating 25lbs foam core with reinforced glass kinda like coosa board but nida core, foamboard.. It is 1/2 inch so i will laminate three pieces to bring it over 1.50".. Probably vacuum bag it to back..or do you think that vacuum might pull it off the mold
I dont know anything about vacuum bagging as I have never done it so am not qualified to answer your question on that. Transom core goes in after the tub is layed up. There are 3 layers of 1808 over the transom core. What are you referring to as "layers over braces"?
