  #34
Old 10-25-2012, 08:49 AM
It's not too late !
Get these S/S deck drains. They have the Ping Pong Ball like Rabud but built-into the drain. You can use the existing deck area and run the water out with heavy gauge bilge pipe out the side vs the transom with a S/S thru hull making sure the thru hull is a little lower than the floor. It does not matter if the thru hull is below the water line.
This is the same set up I have in my flats boat that works perfectly
I have a set of these...did not work for my purpose, PM me if you are interested,
