Old 10-31-2012, 11:44 PM
Tiny Tiny is offline
Know how to back feed your genny through your dryer plug...beats running extension cords all over the place (if you're VERY LUCKY a homies or lowes employee might help you do this on the down low, otherwise you would have needed to figure it out before hand). Make SURE you through your main breaker...when the power does come on it would not work out well.
Fill boat up with fuel pre storm. You're good to go.
When you store your genny first run it dry, then drop the fuel bowl and bag it and the bottom of the bowl. If you let fuel just sit it there IT WILL NOT work months later when when you need it.
Take hundreds of pictures of all your stuff, just in case you need to make a claim later...you never can remember everything you have...save this and other important info on a thumb drive so you can move fast if necessary.
