Old 11-13-2012, 10:46 PM
ct9amr ct9amr is offline
Unless you have the know how this will be harder than it sounds.
Engine angle, right trans (ZF or Velvet), exhaust hoses, water pickup, tank locations and strainer.
The tunnel will also need to be wide enough to swing the correct size prop.
I am not sure if the hull can support all that weight in the middle but I know there were some straight inboard seacrafts.
Pickup a cheap shamrock hull if you really want an inboard as they have a protective keel.
Glen
