Originally Posted by CHANCE1234
. . . That will offset my center of gravity which I could probably compensate for with battery placement. But fuel load obviously changes. What do you all recommend?
Moesly always put the fuel tank right on the CG because, as a pilot with thousands of hours in his logbook, he understood the importance of minimizing changes to the CG. I'd suggest you find out where the below deck tank was located on the later CC's and put yours in the same spot!
