Old 12-04-2012, 11:59 AM
. . . Anybody had their boat in the Bahamas with no bottom paint for longer than 12 days? How long? Could I get by with only painting the drive? Teflon coatings? Other ideas?
Connor,
My boat was in the water for about 14 days during my 700 mile "So. Fl. Circumnavigation Trip" http://s188.photobucket.com/albums/z...t=69122ef0.pbw in the spring of 2010. We were on the move every day except for 4-5 days in Key Largo. The last few days were in the ICW between Key Largo and Palm Beach, which I understand is the barnacle capital of the world. (There used to be a marine test center in the ICW less than a mile from my house where they tested anti-fouling coatings!) Although we did run offshore from Miami to Ft. Lauderdale, and from Boca to Palm Beach, the boat did stay in the water for a couple of days after we got back. I ran it over to Peanut Island at slack high tide where I did a bottom scrub before hauling out. There was very little build up on the Signature Finish paint on the bottom, although there was some marine growth/alge on the Ivory color on the vertical hull steps, and on the transom and flotation tub of the bracket, all areas that weren't scrubbed by high velocity water during planing operation. Most of it was easily removed with a light scrub with a blue 3M pad, although I think I used the chisel blade in an exacto knife to remove a the beginnings of barnacles I could feel on the transom surface.
I've concluded that the Signature Finish urethane paint (which is the only urethane I know of that holds up below the waterline) is so slick that most marine growth is washed off in the areas where it matters if you run the boat every day! Just plan on doing a good bottom scrub of the transom on your last day in the Bahamas!
When I was testing paints before painting the bottom, I also left a piece of fiberglass painted with Signature in the canal off the ICW across the street for about 6 weeks. It had some fairly heavy growth on it, but I was able to scrub off about 80% of it, and there was absolutely no problem with bubbles or adhesion of the paint! While you'll obviously want to use antifouling paint on the outdrive, I think Signature Finish would be a good option for the bottom, especially if you use a contrasting color to highlight the vertical steps like I did in the picture below! Tom can match any color you want if you can send him a color chip; he already has the formula to match any of the Sunbrella colors. Denny
