Old 01-14-2013, 07:43 PM
hugo hugo is offline
thanks guys, im a little worried now because i set the bracket as low as possible to get the most amount of fotation i could get and im at 2.5 inches up above the keel now with only 1 hole left to go up. from what you guys are saying i need to take it to the last hole up and pray it is enough! its only 3/4 inch per hole so id be at 3 1/4 inches up. as for props i have a mirage 19p i was going to try and also a ss michigan wheel 19p or the old faithful aluminum black max 19p as well.oh and im using a miami stainless marine bracket. i sure hope its high enough.
