Bushwacker, what brand 4 blade prop are you running? before i did all the work i tried a trouphy pluss prop but it was horrible. would ventilate badly at the hole shot then run ok but much slower than before. it was a small hub prop with the plastic ring on front to close up the gap on the lower unit(between the prop hub and gear case) and i hade all solid plugs in it.
