Old 02-18-2013, 04:17 PM
cdavisdb cdavisdb is offline
Check the weight limit on the tires. D range is what you want, but what weight limit? If you pull the boat fast and a long way, total 10,000 lbs is a good idea. I had some C rated,1870 lb capacity (total 7480 lbs) that apparently were not enough for this boat.
Owens recommends stainless hydraulic disc brakes by Deemaxx. Given who they are, that should be good advice.
I looked at the tire placement on your boat relative to hull length. Looks to be within an inch or so of mine, maybe less, should be fine if you fix the spring issues.
