Originally Posted by Entourage
Yeah i went through 1 gallon and got 2 coats out of it. I have these what looks like spider cracks in the paint when it dries. I think it may be from the barrier coat not fully curing. I'm not sure but i'm not happy having to buy another gallon of this stuff.
a few dumb questions:
after the blasting - was the bottom finished sanded and solvent wiped down ?
coats of barrier ? alternated grey and white to get the needed thickness ?
when applying the coats of the barrier,did you wait till the barrier was kicked - meaning,use the "thumb test" - touch the epoxy with your thumb,does the epoxy stick to it ?
did you wait till the barrier was fully kicked before painting with antifouling paint ?
you are aware of the recomended application temps of the barrier coat,yes ?
