Thread: 76 23 restore
Old 03-03-2013, 10:44 PM
scowman scowman is offline
Hi Ken,
First I measured the width of transom at Top, Middle, and Chine to chine also from Port gunnel to Starbord Chine . I reacorded all these measurements First and would re -measure so to keep track of the movement of the hull.
Then i used a block as a jig and traced the outline inside the hull..
Then i used a 4" angle grinder with a diamond blade. and cut on the lines
When I got to the top cap. I pulled all the screws out about a third up the lenght of the cap and used my Hoist to lift it up.. I then cut the rest of the transom up.
I put a few blocks to hold the cap up and just started to pry and pull the rot off the back...
I used a Bostich 36" wrecking bar, a eastwing claw hammer , a craftsman ballpin, and 2 steel flat wedges and some old large flat head screw drivers..
The rot was significant so it really wasn't so bad... as for the corners.. I tried to get the most out in the middle of the transom and then with the hoist and some notches in the wood. I used the hoist with a rope tied to the notch to Pull up and it rolled out the plywood for the most part in one piece...
when all the wood is out. I used a mirror to inspect the back side of the glass around the perimeter .. and a very sharp hand chisel i used to chisel out the remaining wood from the glass...
I then used a 7" angle grinder with 36 grit and ground the inner glass down. In some places I had to use a 4" flap disc wheel for the stubborn areas.. I washed the area with acetone and then I scrubbed and Pressure wash with degreaser..
Thanks, That's the best response I've ever had on any board, any topic, any time!
If I could ask another question, how did you settle on the remaining skin to edge distance? I have seen some a couple of inches longer. seems the longer it is, the better/stronger the tie in will be but the hard to get the remaining wood out. Are you going to wrap the glass around the edges?
