Old 03-11-2013, 07:22 PM
Rondo Rondo is offline
If you're using plywood with polyester resin for your project, prime the plywood with resin thinned 20-25% with styrene and an appropriate amount of hardener ( Make sure that the plywood is fully aired so that any residual chemicals evaporate off the surface.) Give it a couple of coats and let it set in and dry. Your glasswork will then adhere to the plywood with a much stronger bond.
