I picked up a lappy project boat last month and finally had time
to clean the carbs and check the motor out that came with the boat.
It is a 1975 Johnson with a 20 inch shaft and no TNT....
After soaking the carbs and reinstalling, I checked the compression which comes in at 128lbs. on all four cyclinders... There was a a bad ground
on the number one coil of which I fixed as well..
Has 4 new plugs to boot.
Make a long story short this ole' girl runs like a top!!!
It could use a new impeller and a gear lube change to make it right..
It comes with the control box, cables, (not the best, but work)
SST prop, looks to be 13 X 19 not sure though....
I have this listed on CL for 500 clams!
Family price on CSC $300
It starts right up and runs great!
Currently mounted on a roll around stand for demo purposes.
I have had a couple of tire kicker calls...
Hey, it is what it is! Oldie but goodie..
Come and get it at Area 442..
